Best thread sealer for alum A/N fittings >
Old 05-04-2012 | 04:28 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default Best thread sealer for alum A/N fittings
What is the best stuff to use on alum A/N fitting to stop them from gauling up when you tighten them,so when you try to remove it don't pull the threads.I'm talking pipe thread side of the fitting JOHN SR
Fenderjack is offline
Old 05-04-2012 | 05:42 PM
I don't do it for a living, but have good success with loctite or permatex with PTFE.
maddad is offline
Old 05-04-2012 | 06:06 PM
I use a small dab of Permatex with PFTE also, no leaks. Brian
baja_brian is offline
Old 05-04-2012 | 06:27 PM
Fenderjack's Avatar
but do you have problem with them gualding when you try to remove.
Old 05-04-2012 | 07:35 PM
Default fixx
i use 2 types depending on what im doing,,on steel i use this ..
http://www.ebay.com/itm/Gasoila-1-pt...item3a66568bd9
on aluminum..http://www.ebay.com/itm/Gasoila-FasS...item3a66568bcd
FIXX is offline
Old 05-04-2012 | 11:50 PM
i use loctite pts,i have not had any galling.
mike tkach is offline
Old 05-05-2012 | 10:36 AM
I use ARP thread sealer on the pipe side and a little anti-seize on the AN side. Never any problems.
Young Performance is offline
