info on the jag cat cobra is sell'n??
Once bittin' by the kitten, there ain't no quittin'!
That Jaguar 35 is one BAD-ASS ride, i saw it being rigged and it has the BEST of everything! Not to mention it is build with the most sophisticated materials available and will perform like a raped ape in rough water...can't go wrong - Good Luck!
Joe... why don't you just call Angel @ Cobra...
tell her your an oso member and I said to call.
She'll give you whatever info you need.
305.893.5018
If you wanna talk w/ her over the weekend... let me know.. I'll be talking with her shortly.
MJ
305.893.5018
MJ
Rick had the finest of everything put into that boat, probably close to $500k, maybe more, EVERYTHING is trick!!! I personally rode in the boat on one of the test runs and it clocked 136 MPH at the time. Meet with Randy and check it out, it is a steal for what he wants, all it needs is someone who knows how to run a boat!
ssherman - the ONLY reason the 36 Skater dominated is because it NEVER ran against a "set up" Jag...Ain't no way the skater can hang with a Jag Cat in rough water...plus,, the Jag is MUCH, MUCH safer!
Hey Joe Ryan Beckley here, we met at St Could I have the blue and white 24 SKATER. Anyway that boat is a nice piece and was rigged by TNT Custom Marine. HP to HP though it is not as fast as a 36 Skater.
