Marine tex on gil exhaust plumbing >
Old 05-09-2012 | 01:12 PM
Default Marine tex on gil exhaust plumbing
Will marine tex work on the exhaust plumbing that feeds the bottom of the manifiolds. I removed the stainless plumbing to have them powdercoated. A couple holes only have 2 or 3threads left. I don't care if they become permanent, because I will just replace the exhaust if I ever need to remove them again. What kind of sealant can I use on the rest of the fittings that have a decent amount of threads left?
FBRONCO is offline
Old 05-10-2012 | 12:29 PM
MER Performance's Avatar
If it's only missing threads and the manifolds are not completely ate up. I would take a die grinder with a rotary file, clean all the bad material out have someone tig weld alum back in, drill and re-tap pipe threads.
MER Performance is offline
Old 05-10-2012 | 02:12 PM
bcfountain's Avatar
Registered User
i think a better product is j b weld.clean the surface good w/carb cleaner and rough the surface up and seal her up.i have had good results.
bcfountain is offline
Old 05-10-2012 | 03:51 PM
Would it be possible to drill the hole for the next size larger NPT, and tap it? Then install a new fitting, or a bushing? I dont like the idea of "glueing" it.
MILD THUNDER is offline
Old 05-10-2012 | 04:03 PM
+1 Stuff is amazing.
JTeam is offline
Old 05-10-2012 | 09:17 PM
There are a couple threads left on half the hole and the other half has a few more threads than that. So I think it will screw in tight, just might not seal up. So that's why I'm leaning towards just using jb weld or marine tex. Also the manifolds were just powder coated so I don't really want to attempt any welding.
FBRONCO is offline
Old 05-10-2012 | 09:35 PM
Marine Tex (Big Fan) The gray is stronger than the white Good luck, Greg
greg bakker is offline
