Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Gelcoat 101 I need all the help I can get >
Old 05-09-2012 | 10:19 PM
Rookie's Avatar
Question Gelcoat 101 I need all the help I can get
I finished filling the little hook and imperfections in the bottom of my boat with 3m Premium filler. I now need to protect this with gelcoat. Do I just shoot gel over the 3m filler? I have read every thread about spraying gel on this forum and have googled and Youtubed the subject to death.
I have never sprayed gel and kind of confused with the waxed, nonwaxed, PVA over it and mixed with Duratech highgloss. I have the last 8' of the hull that needs to be shot to cover the filler.
I have bought 2 of the infamous Harbor Freight $15 disposable guns and I also a real gelcoat gun.
http://www.bottompaintstore.com/gelc...3885f36a1b1490
I am a little scared what gun to use. The real gel gun I think I would put it on to thick and will sag with less control. I feel that I could finesse the gel better with the $15 guns with the tip drilled out.
Also I have been looking at trying to spray these gels for a one step finish.
http://www.jmsonline.net/fib-105671.htm
http://www.boatersland.com/hib701500.html
If someone just wants to say order this..... and this ..... and this.... and mix to these ratios and then spray with this gun I will
Thanks,
Jason
Rookie is offline
Old 05-09-2012 | 10:57 PM
glassdave's Avatar
Neno the mind boggler
The whole process depends largely on how much coverage you need. If the filled/faired ares are white as well as the surrounding are you can go with a gel/Duratech mix through one of the harbor freight guns with the tip drilled out a bit. If you have a lot of spots that need coverage you may need to spot cover those first with a waxed gell and re sand it a bit.
After we zero in on the process tailored to your boat we'll work on a grocery list
08 OPA High Points Champion
glassdave is offline
Old 05-09-2012 | 11:20 PM
Rookie's Avatar
The bottom of the boat is white gel (dingy) and the filled/faired area last 8' outer chines in is 3m filler area is with white hardener. So it has a light yellow hue.
I will get pics this weekend.
Rookie is offline
Old 05-12-2012 | 01:08 AM
hey jason,
did you lengthen the inner strakes ?
and when you drill out the tip on the gun post the drill size
good luck and get those pics up
dan
outonsafari is offline
Old 05-15-2012 | 10:56 PM
Rookie's Avatar
Ok, all is smoothed out and straight. I do not need anything filled with gel. I would like to do the straight gel/Duratech if this will bond to the 3Mpremium filler. It is prepped as good as if I was going to lay down paint.
http://www.shopmaninc.com/polyesters.html
http://www.shopmaninc.com/polyprod.html
Also this might be a real dumb question, could I just use a roller and roll it on? I am going to finish sanding when I'm done.
Rookie is offline
Old 05-15-2012 | 11:05 PM
Rookie's Avatar
Originally Posted by outonsafari
hey jason,
dan
The inner strakes are going to be after I finish the bottom. Then I will have a before and after for both. I also did not believe that truing/blueprinting?? the hull would be so labor intensive. As I mentioned in another post I have a new respect for those that do this for a living. I should have flipped the boat last year and done this while it was gutted.
From what I've read you drill it out to 2-2.2mm. And pics will be up soon.
I think I will start a before and after thread in the Scarab section. Seeing that I have replaced/upgraded everything on this boat.
Rookie is offline
Old 05-15-2012 | 11:22 PM
glassdave's Avatar
hey jason,
dan
I use a 5/64ths (2mm) on the HF gun, make sure that you dont get into the protruding part of the tip and knock it off otherwise it will not draw fluid through and just pressurize the cup (something brought to my attention recently)
Old 05-15-2012 | 11:27 PM
glassdave's Avatar
yes its fine over the VE filler, be careful you arent to fine on the sanded grit. For gel i only go to about 180 or so. Rollers are tough to control uniform film thickness stick with a gun.
Old 05-15-2012 | 11:45 PM
Rookie's Avatar
Part#'s Dave, Part #'s LOL
This is what I am looking to buy.
GEL-W100 1 Gallon $ 44.00
DURA-904G Gallon + Catalyst $83.95
Rookie is offline
Old 05-16-2012 | 12:13 AM
glassdave's Avatar
lol . . . . yep, thats all ya need. White gel and DURA-904 i would probably get three and three for starters
hey . . . . wheres the pics ya promised back on the tenth
