looking for answers? >
Old 05-15-2012 | 04:01 AM
Default looking for answers?
I have a 98' 322, but not sure on the holding capacity of the fresh water tank, the pump out head (grey water tank), or even how to get the sink or the pump out to work? Is there a switch on the dash along with the water pump switch on the panal, like a ACC. switch? Any help or advice would be great.
Thanks,
Mike
blown wages is offline
Old 05-15-2012 | 07:21 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
You're probably right around 15 gal on each. Do you have vacuflush head or a porta-potty with a holding tank? (could be less holding with a porta-potty)
There's nothing on the boat that does the pumping out. You go to a pump station, remove the cap and just suck the grey water out.
You should have a switch on the panel for the fresh water pump.
Baja_342 is offline
Old 05-15-2012 | 06:29 PM
Talking
Thanks for the response and all your help
Old 05-15-2012 | 11:24 PM
yep its the acc switch to make the sink pump work
Yoda_Man is offline
