Stand off box or extension box >
Old 06-29-2002 | 12:35 AM
Default Stand off box or extension box
I am new to high performance boating, and would like to know what a extention box or stand off box does for an outdrive.
onesloryd is offline
Old 06-29-2002 | 10:40 AM
mcollinstn's Avatar
ditto on Troutly's post.
Picture your boat as a seesaw, with the pivot point at the transom. If you trim the drive up, you see that the prop thrust pushed both forward AND down on the end of your seesaw. This down component pushes the stern down and lifts the bow.
Now move the drive off the transom a foot. You now can see that the DOWN component has far more leverage and, thus, effectiveness in lifting the nose of the boat/seesaw. Now, you can either lift the nose more, OR use less trim angle to lift the nose like you could before. Any time you can use LESS trim, more of the prop force goes towards moving the boat forwards.
The LAND & SEA ads for the stern jack do a good job of illustrating how the water cleans up as it gets further away from the transom. (a stern jack is not an extension box, but sort of does similar stuff).
mcollinstn is offline
johnnyboatman
0
10-19-2008 09:14 PM
Fenderjack
24
09-30-2006 10:49 PM
raymo1979
3
08-08-2006 04:54 PM
eurotank
4
10-24-2005 01:24 PM
SCARAB98
Scarab
0
03-15-2005 06:36 PM
