Cam Size 454
Old 05-17-2012 | 08:52 PM
Default Cam Size 454
Can anyone tell me what would be the best size of cam to install in two bbc's. I want it to have a good lope.
benthompson292 is offline
Old 05-17-2012 | 09:04 PM
call bob madera,marine kenetics,he will fix u right up.
mike tkach is offline
Old 05-17-2012 | 09:16 PM
Rookie's Avatar
What is more important to you the "lope" or overall performance of the cam?
Rookie is offline
Old 05-18-2012 | 01:21 AM
That sure is a general question that requires much more detailed information to give any kind of answer.
Philm is offline
Old 05-18-2012 | 02:40 AM
A "good lope" will suck water back into the cylinders with stock exhaust and hydrolock your engine.
Griff is offline
Old 05-18-2012 | 07:02 AM
If you like "lope", you may want to invest in some aftermarket exhaust with dry tailpipes.
Are we talking flat tappet, hyd roller, or what?
MILD THUNDER is offline
Old 05-18-2012 | 09:40 AM
I have 2ea Hyd roller mag cam take outs in the classifieds. What cams are you running now?
Itsallgood995 is offline
Old 05-20-2012 | 11:21 AM
Right now these motors are out of a family friends mud trucks that my dad got for a pretty good deal for me to put in this 1991 Scarab Viper 31ft I bought as a project. I was told that we would need to put a different size cam in them since the came out of a vehicle. Is this true?
Old 05-20-2012 | 11:52 AM
Yes...it is true and you also need to change the exhaust valves to inconell. I have 2 (excellent condition) 502 mag roller cams...$50.00 each plus the ride. If you are running flat tappet cams, I would suggest that you run these Comp Cams... http://www.summitracing.com/parts/CCA-K11-244-4/ or http://www.summitracing.com/parts/CCA-11-244-4/ .
I have these cams in my motors and I am very pleased with them. They will give you the lope that you are looking for and they will work without any reversion issues with bone stock exhaust.
http://www.youtube.com/watch?v=KYQxeahHQ_Y&feature=plcp
http://www.youtube.com/watch?v=Mb2y3vn0exM&feature=plcp
any questions...just holler and I will try to help.
pslonaker is offline
Old 05-22-2012 | 09:08 PM
Your not having problems with water getting in the engine with those large cams using stock manifolds? I couldn't tell for sure from the video, but maybe they aren't stock manifolds. Or is that why you have the idle up to 950?
Either way sounds good.
cp5899 is offline
