How does water get in front of the steps >
Old 05-18-2012 | 03:01 PM
Default How does water get in front of the steps
If the boat is stored dry and the outside exit ( for the foreward bilge pump ) is plugged ?
mcprodesign is offline
Old 05-18-2012 | 03:10 PM
eddie's Avatar
Comes in the hatches or water leak from the fresh water system. I've seen it do both.
eddie is offline
Old 05-18-2012 | 06:24 PM
Maybe when we washed it huh
Old 05-18-2012 | 06:26 PM
eddie's Avatar
Put someone in the cuddy and then spray the deck down again. I bet you figure it out.
eddie is offline
Old 05-18-2012 | 07:20 PM
266ltd's Avatar
Depending on year and model I've heard and had an issue w ice cooler drain goes to bottom of v and never gets run back to drain...I just made my cooler drain out the side I also noticed if u get any rain water it's runs there from grab rail...once u get it there it can take awhile to dry out...I shopvac dry and put a fan on it and keep out of the rain and adjusted cooler drain haven't had a problem since...
266ltd is offline
Old 05-18-2012 | 10:20 PM
I got no kitchen , no water ( Plummed) no drains. just seats, twin step 38. I has to be something. It stays dry and then when itake it out it has water in the area in front of the steps. Carpet never wet after washing it.. I'll have to check that when washing it. Anchor locker had water under it where the anchore wore through the floor. Pummped that out and glassed it up.. Plut a drain plug in there so i could check if it has water in it somehow. Ill have to check that too. Thanks
Old 05-19-2012 | 07:04 AM
I seem to always find water under that step as well. I use a shop vac to get it out and somehow water always seems to find its way back. If I ever figure it out I will let you know. There have been several threads about this issue.
Spinletto is offline
Old 05-19-2012 | 09:48 AM
Registered User
Hi Chad,
How is the new boat? Looks nice.
The water thing under the step, I figured it out on my 35, here is what I found.
1. the boat sits slightly bow low when on the trailer.
2. the ice chest drain goes only part way back and dumps outboard of the stringers.
3. if you pull the plug on the ice chest when the boat is on the trailer the water goes forward and ends up under the step. If you pull the plug when the boat is still floating it is stern low and the water will go into the bilge and will not come forward.
4. the deck drains in the cockpit area do the same thing as the ice chest.
5. be sure the drains at the back of the stringers are open to let any water that gets in outboard of the outer stringers can drain to the center.
6. most Fountains leak under the molding at the swim step where the deck is mated to the hull. This can do the same thing as #3.
hope this helps.
Dave
Dkahnjob is offline
Old 05-19-2012 | 09:53 AM
Thanks Dave, I don't have any running water, cooler or Kitchen. I think it might be the steps themself. Maybe on deceleration it gets in front of the steps. My non step bottom boat never had this problem so I did not pay much attention to the other threads.
Old 05-19-2012 | 02:47 PM
leonard's Avatar
mcprodesign,
I thnk its a San Diego thing I have the same problem with my 47' I have no idea where that water comes from. can only say mine comes from the galley sink outlet but I'm still searching let me know if you find out anything else.
P.S. Maybe I see you on the water this season?
leonard is offline
