Looking at a 99 advantage 340 offshore
I looked at it last year. wasn't looking for another boat, just was in the area and saw the add. Seemed like a clean boat. But is/was in salt water. Don't understand the dual tanks in the bilge. Mine has one big one under the floor in the center. 502 MPI's are good motors. If I remember it only had a little more than 200 Hrs. Not sure why it has B-max drives. But they are good drives. Cabin yellow is a bit much. I paid 69K for mine, it's an 2002 that needed a lot of work. Check the bottom for hook. 34 is an awesome boat that you can put big power in. Also the black rub rail has to go, but that is pretty easy to replace.
