Bravo 1,50 to 1,36 Prop ? >
Old 05-20-2012 | 04:27 PM
Default Bravo 1,50 to 1,36 Prop ?
Going from drive with 1,50 - Bravo 24P prop to Bravo drive 1,36 how big Bravo prop do i need? Got a 26, can I use it? It`s a single Rib boat,broke the 1,50 drive. (HP 500 EFI)
502 Magnum is offline
Old 05-20-2012 | 06:38 PM
Default 1.5
keep you 1.5 gear unless you run out of prop. you will make a mistake
jerryhaney is offline
Old 05-20-2012 | 07:54 PM
if you are running a 24p with the 1.5 ratio,you will need less pitch with a 1.36,probibally a 21p,or a 20.
mike tkach is offline
Old 05-21-2012 | 11:24 AM
Anyone better????????
Old 05-21-2012 | 11:29 AM
Yeah, if your gears Are still good shape, why dont you pull the 1.36's and replace with the 1.50's? Would eliminate any guesswork...
Shag555 is offline
Old 05-21-2012 | 02:42 PM
You are right,to clear up a litle here I`m going to use a HP 500 EFI with 1,36 drive and I`m not sure what prop to begin with,the boat is a light Rib 28` boat,thanks.
Old 05-21-2012 | 07:48 PM
stay with the 1.50,1.36 and lower pitch prop you will hate,mercury and others have tried all these combos thats why you have 1.50
proboat-wes is offline
Old 05-22-2012 | 01:16 AM
A 1.50 to a 1.36 will need about 3" less pitch prop. By going to a 1.36, you will have much harder time finding the correct style of porps in a small enough pitch.
Griff is offline
Old 05-22-2012 | 03:00 AM
Smile
Yes you are so right,I give up the 1,36 plan,thanks.
Old 05-23-2012 | 10:35 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Just another shout out to stay with the 1.50:1 ratio.
Test you 24 if this is new power and you can decide where to go from there.
Brett
[email protected]
bbladesprops is offline
