Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
GlassDave need some paint help.... >
Old 05-21-2012 | 04:40 PM
tcwcar's Avatar
Joe
Default GlassDave need some paint help....
I'm thinking about painting my white gel, white paint, BC/CC, tryed to wetsand the gel and buff just to many discolorations, should I regel or paint and if paint, whos PPG, Dupont, what clear or should go with, or should i use imron, algrip or something like that....thanks for any help...joe
tcwcar is offline
Old 05-21-2012 | 09:23 PM
glassdave's Avatar
Neno the mind boggler
If its a single color with no graphics i would shoot single stage PPG Concept. Great stuff and after its buffed it actually looks like fresh gel. Its easy to work with and is pretty durable. I use color # DCC-91050 on all complete resprays, good lookin clean white that goes with all other colors.
08 OPA High Points Champion
glassdave is offline
Old 05-22-2012 | 12:10 AM
scippy's Avatar
I use color # DCC-90150 on all complete resprays, good lookin clean white that goes with all other colors.
Dave......On the PPG concept single stage which # is correct...DCC-90150 -or- DCC-91050? on a differnt topic in this section you mentioned the latter one......just want to be sure.
scippy is offline
Old 05-22-2012 | 03:37 AM
Pete , are you getting ready to spray the Mag at this point in time.
Glassic R.T. is offline
Old 05-22-2012 | 06:57 AM
glassdave's Avatar
oops my bad, good catch i was pretty tired when i typed that it is 91050. Thanks
*fixed*
Old 05-22-2012 | 03:14 PM
tcwcar's Avatar
Joe
Dave got grafics on sides, would like to use BC/CC, want your expertics on which is the best paint / clear to use, PPG clears 2002, 2021, 3000, 4000, which one or some other, Dupont????, and how durable is BC/CC on boats......
tcwcar is offline
Old 05-22-2012 | 07:33 PM
J-Bonz's Avatar
Dave,
What primer to you suggest using with the Concept paint....?
J-Bonz is offline
Old 05-22-2012 | 09:36 PM
scippy's Avatar
Still aways off, but the time creeps closer as I'm just getting done with all the stringers now. Still, seems a million miles away!!
scippy is offline
Old 05-28-2012 | 10:07 PM
I'd use any good quality epoxy primer and dbc color, 2021 clear... I've had good luck with this in the past...
wtfo is offline
