bravo 1 to xr lower.
Old 05-22-2012 | 01:32 PM
Default bravo 1 to xr lower.
I have a question. Will a bravo xr lower bolt up to a bravo 1 upper. The only reason I ask is I have a set that I can install if it will work.
If it does work are there any mods that need to be made and will my 23 mirage plus props work.
Thanks in advance
BIGMC69 is offline
Old 05-22-2012 | 01:38 PM
Mbam's Avatar
Offshoreonly Advertiser
How old is the upper? Unless it is one without the oil passage is no problem. You will have to change to the XR prop hubs.
Mbam is offline
Old 05-22-2012 | 02:31 PM
The drives are 98's
BIGMC69 is offline
Old 05-22-2012 | 04:21 PM
98's
BIGMC69 is offline
Old 05-22-2012 | 08:59 PM
I had a 1995 bravo1 that i bolted up a xr lower to.I would assume that your 98's would be the same
mark
27 avanti is offline
Old 05-22-2012 | 09:06 PM
im not sure about the prop thou,when i switched lower i also went to a 5 blade prop and needed diffrent spacer.I forget if it was because of the prop or the new lower.
mark
