whats the ideal water pressure with this setup >
Old 05-22-2012 | 08:55 PM
Default whats the ideal water pressure with this setup
trs drives at 4000 rpm water pressure is at 19psi already going to install releif valve because it was just increasing. whats the ideal psi range it should be?
mookster is offline
Old 05-22-2012 | 09:41 PM
i like under 10 lbs
mike tkach is offline
