Go Back  Offshoreonly.com > Owners Forum > Nordic
My next adventure - SCX lower >
Old 05-25-2012 | 12:06 AM
CB-BLR's Avatar
Chris
Default My next adventure - SCX lower
I got tired of destroying SC lowers on my SCX drive...and found a used SCX lower...blue printed by Wilson...in the classifieds.
Testing to commence:
Chris
CB-BLR is offline
Old 05-25-2012 | 01:22 AM
Chris
NIce. Any idea if a silent choice exhaust can be used on an SC or SCX drive? I did the coroplast under my bow cover BTW. Thx.
xcpilot is offline
Old 05-25-2012 | 07:01 AM
Airpacker's Avatar
How many hrs were you getting out of the SC lowers?
Airpacker is offline
Old 05-25-2012 | 02:11 PM
CB-BLR's Avatar
Chris
A couple a season.
I have broken just about every moving part inside a SC lower....at least twice.
Chris
CB-BLR is offline
Old 05-29-2012 | 06:39 PM
jns
Chris
If I leave a 600 as stock how well do you think the xr1 lower will hold up?
What tabs did you install.
Sharp!
jns is offline
Old 05-29-2012 | 07:52 PM
CB-BLR's Avatar
Chris
Originally Posted by jns
Chris
Sharp!
An XR drive will easily live behind a stock 600sci ... or a Whipple Stage III for that matter.
Dana 900 tabs...installed with the dead-rise...1.5 inches up from the bottom
Chris
P.S.
A stock 600 sci will want a 1" spacer between the upper and the stock length lower in order to reach its peak efficiency.
A stage III will want a .5" spacer.
Chris
CB-BLR is offline
Old 09-11-2012 | 01:05 PM
Any updates? How did the boat handle with the SCX lower? Any speed loss or gain? How many hours do you have on the SCX lower now?
I am tired of breaking my SC drives also!
offshorexcursion is offline
Old 09-18-2012 | 03:29 PM
CB-BLR's Avatar
Chris
I have about 20 hours on the SCX lower now...without even a sign of metal on the magnets.
I am running it an inch higher than my SC lower...and am getting aproximately the same slip numbers.
Propshaft depth below the pad is now 2 inches....slip is aproximately 13% at top end.
My top speed went from aproximately 105mph to 103 mph...but with zero issues.
The boat handles better with the SCX lower.
Hope this helps.
Chris
CB-BLR is offline
Old 09-18-2012 | 06:59 PM
Chris
Refresh my memory. How much HP do you have?
Ray
raytart is offline
Old 09-19-2012 | 09:27 AM
CB-BLR's Avatar
Chris
Originally Posted by raytart
Chris
Ray
1040 hp
MCOB hull
Chris
CB-BLR is offline
