525 Seawater pump lube >
Old 05-25-2012 | 12:37 AM
Default 525 Seawater pump lube
Trying to drain and fill the seawater pump oil without removing the pump. I know there is a screw on the side, is that to drain and refill? If so, since the screw is located on the side, how do you get the oil in?
thanx
http://www.offshoreonly.com/forums/3367682-post8.html
bert4332 is offline
Old 05-25-2012 | 01:49 AM
http://www.offshoreonly.com/forums/g...-sea-pump.html
TWIN-SPINS is offline
Old 05-25-2012 | 01:59 AM
Default fixx
i like to remoove them and clean it out and make sure all the bearings look ans feel ok,then refill with merc gear lube.
FIXX is offline
Old 05-25-2012 | 07:09 AM
+1...best way to insure all the old oil is out is to remove the whole thing & drain it. Plus, it gives you the chance to check the condition of the mechanical pump components and the bearings, like MrFixxall stated. Only extra work should be disconnecting fuel lines & serpentine belt off the pulley.
barrete1 is offline
Old 05-25-2012 | 07:45 AM
While my pumps were off, I drilled and tapped a extra screw at the bottom of the boss. I then added a magnetic drain plug screw so I can just pull that to drain the pumps and also check for metal/collect metal.
Also, when I pull the pumps off, I installed the Keith Eickert Fuel pump upgrades after rebuilding my seawater bumps and replacing my fuel pumps only to find out my engines were spaced to close together and my plumbing wouldn't work so I have (2) brand new KE pumps, (4) -8 AN 90 degree fittings and 6' of stainless braided AN hose for sale lol...
teamsynergy is offline
Old 05-25-2012 | 06:04 PM
Default fixx
BTW if you remove the screw and nothing comes out its either out of oil or it turned to grease from the heat and has to be removed anyways..
FIXX is offline
Old 05-26-2012 | 01:37 PM
I found it easier to line every up after all of it was removed. Just a FYI, use a star pattern when tightening the seapump, I didn't and blew a hole right through the intake when I started the motor up to look for leaks. Luckily I scored another before this holiday weekend.
bert4332 is offline
Old 05-26-2012 | 02:03 PM
sunchaser796's Avatar
Its nice to know that everyone has their own thoughts on how to do things. What I see most about inputs is they are never 100% correct.The chamber for the oil is to lubercate the fuel pump arm since it operated off an ecentric. There should never be metal in the chamber. If its out of oil, that means you have a bad seal. It could also mean the the fuel pump is leaking fuel into the chamber and is either leaking thru the front seal or worst yet it is leaking to the water pump housing wash any traces away. Now here are the real facts that know one really knows about. Ever since Mercury started mounting their pumps on the water pump housing the thought of ethonal fuel was never considered a problem. The fuel pump was never designed to be mounted sideways. The fuel would eat the rubber inside the pump and the leaks would start. Fuel pumps would never last more tha a year. They were having to replace them. Everytime I rebuilt the water pump, I also checked for fuel in the oil. Everytime I would replace the fuel pump. Mercury knew this was a problem.So installing drains in the bottom of the housinf just pull it off the engine and check for fuel. It does'nt take that much more work to do so. This service should be performed once a year.The bearings relie on the oil for lubercation. With fuel the will not last long. Theonly option that is left is to replace the fuel pumps with electric, replace the the mechanical with a cover plate and gasket and check once a year.Good luck with doing the right thing.
sunchaser796 is offline
Old 08-09-2014 | 07:55 PM
Biggus's Avatar
It seems that every one of these pumps seem to bleed gasoline into the pump oil. Since there seems to be now way to avoid this, I fill the reservoir with 2 stroke Klotz castor bean oil. (unsurpassed film strength and blends with gas)
Biggus is offline
Old 08-27-2014 | 12:17 PM
So is this the norm for fuel pump to bleed gas into sea pump oil or is that signs of a bad fuel pump. Never had a problem with fuel/sea pump until now, blew oil out of sea pump with strong smell of gas.
ozarkdevil is offline
