Anyone heard of boat angle causing oil pressure problems?
Hey guys, I just noticed I'm loosing oil pressure when I get to 3800-4000 rpms, I'm going from 40psi down to 20psi, when I drop down it immediately goes back to 40psi. I've read lots of different possible causes. The one that most are saying is the problem is the boat angle. Anyone heard of this ?
Any input will be greatly appreciated
Definitely sounds like a windage issue caused either by a poor windage tray design or high oil level. The higher oil level could be caused by an increased engine angle. That will cause the oil to pile up at the rear of the oil pan.
Is this a new problem? Is this the first time it has been run or did this problem just arise?
Eddie
Eddie
