where are you taking your water press readings from? >
Old 05-28-2012 | 08:32 PM
Default where are you taking your water press readings from?
on the side of the block? intake?
mookster is offline
Old 05-28-2012 | 09:15 PM
I have closed cooling engines and I pickup the sea water pump pressure what at the inlet to the heat exchanger. Basically this is the first stop after the water leaves the pressure side of the pump. My oil coolers are on the suction side of the pump.
502ss is offline
Old 05-28-2012 | 09:24 PM
c_deezy's Avatar
Side of the block, on one of the drains currently. In the past, I prefer to pull from the intake manifold, but on the current motor I had to go from the side of the block.
c_deezy is offline
Old 05-28-2012 | 09:41 PM
Is pulling it from the sea strainer too early or does it need to be after the pump?
Revd Up is offline
Old 05-28-2012 | 11:52 PM
LOL, you're not going to be reading any pressure on the suction side of a pump.
Fast Algae is offline
Old 05-29-2012 | 11:07 AM
seltzer's Avatar
Mine are off the block and they have a tendency to clog up.
seltzer is offline
Old 05-29-2012 | 01:19 PM
Thermostat housing. Had a plugged 1/8 in hole in the stock housing, why not use it.
Ken
minxguy is offline
Old 05-29-2012 | 10:44 PM
Ken
ditto
cloudmaster_321 is offline
Old 05-29-2012 | 11:13 PM
In the intake or thermo housing. As mentioned, going in the drain hole in the block runs the risk of clogging up with sand/silt, etc.
Eddie
Young Performance is offline
Old 05-30-2012 | 07:43 PM
tcelano's Avatar
Some thermostat housings have extra NPT ports. That's what I used on my last motor.
tcelano is offline
