Outlaw 24 top speed only 52???? help
Need some help here. I have a 98 Outlaw 24 with a 502 mag. Had it out over the weekend and it just doesnt seem to be that quick and I dont get why. I have a bravo 1 1.5 drive, Mirage plus 23p prop and I was only hitting 52mph on gps at 4500 rpm. I did have 4 people on board and probably 3/4 tank but that doesnt seem like it would drop mph from where it should be which from what I am seeing should be mid 60's??? Any suggestions as to what to look for or what may be going on. I am completely baffled.
Havent done a comp test. Motor has 220 hours on it. Boat came from Illinois and was purchased new by my father in law. I bought it off him in the fall and brought it out to RI.
Seems way low. Grandfather has a '92 24' OL w/454 mag motor, bravo, and 21P prop. I have no trouble getting to 65 with two people and 3/4 tank. Sorry, don't recall the rpms, but this is a completely stock boat with about 300hrs on it (he bought it new).
What was your father in law getting out of it?
If you stored it outside, check your bilges- sounds stupid - but........i towed my 80mph boat from fl. To san diego with the drain plug out. Took it out a couple times, always removing the plug. It was noticably slow-i was ready to take it to the shop when kneeling to check my prop i noticed color inside my drain hole .........a @#$# plastic plug fitting perfect from the inside. I cleared it and nearly an hour later it was empty! ........and thats how a 1000lbs+/- of florida rain water got to so. Cal. And my speed was back
