Go Back  Offshoreonly.com > Owners Forum > Powerquest
PQ with 496, might want to save this info >
Old 05-31-2012 | 07:47 AM
Default PQ with 496, might want to save this info
[IMG][/IMG]Monday after hard weekend of boating, boat starts 2 beep alarm at other end of lake. Checked all fluid levels, narrowed it to Starboard engine. No manuals came with my boat. Found chart on beeps online. Buddy let me use his scanner. IAC code, told to clear code and should be fine.
kept looking, told to look for melted plug to IAC, also noted that the plug was a Motocraft number along with IAC.Re-checked by pulling IAC off. Plug on IAC started to melt, Motocraft part was correct. Sometimes google is handy!
[IMG][IMG][/IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
BlueOval is offline
Old 05-31-2012 | 07:56 AM
Constant tone alarms are for:
1.) engine coolant temp overheat,
2.) low engine oil pressure,
3.) engine overspeed,
4.) exhaust manifold cooling temp overheat
5.) sea pump PSI low
Constant beep alarms are for:
1.) low outdrive lube level.
Two Alarm beeps every 60 seconds are for:
1.) Faulty cam,
2.) IAC,
3.) MAP,
4.) MAT,
5.) knock sensors.
6.) open/short in the engine cooling temp circuit
7.) open/short in fuel injector wiring circuit,
8.) open/short in oil PSI circuit,
9.) open/short in exhaust manifold cooling temp circuit,
10.) open/short in sea pump circuit,
11.) open/short in throttle position circuit
BlueOval is offline
Old 05-31-2012 | 08:28 AM
Knot 4 Me's Avatar
You got lucky it didn't melt the plug on the wiring harness. Some have even roached the ECU!
Are the two bolts that hold the IAC down torx or metric? I need to replace mine (330 hours) and my motor is tucked up under the transom lip so I will be doing it blind.
Knot 4 Me is offline
Old 05-31-2012 | 09:14 AM
Alan wrench took mine off.
BlueOval is offline
Old 05-31-2012 | 09:39 AM
Knot 4 Me's Avatar
Thanks!
Old 05-31-2012 | 09:57 AM
The gasket, if not supplied s/b Motorcraft CG-763. Also, Ford/Motorcraft does sell the harness side connectors...WPT-XXX not sure of this number...Blue Oval can you dig through your Motorcraft catalogue?
Need4SpeedGTCS is offline
Old 05-31-2012 | 10:39 AM
Blue Oval...further to the bad IAC be sure to look for the cause. The melted connector is typically a result of high resistance, resistance builds heat, the connector at the IAC was the weakest link. Check the harness connector and all grounds...what could be next...ECU? Make sure the connector seal is in good shape and use some silicone di-electric grease on the terminals.
Knot 4 Me...why would you want to change an IAC that is working? It's an electronic solenoid not much different from a fuel injector. Sometimes they get gummed up from blow-by gases but then just clean the valve portion. How does the boat idle? Does the engine stall out when coming off the throttle?
Just trying to be helpful...not meaning to be a smart-azz.
Old 05-31-2012 | 12:52 PM
Knot 4 Me's Avatar
I've asked myself the same question...why am I considering changing out a perfectly good working part. The boat runs perfect so why mess with it. I keep a new IAC on gasket on the boat in case the IAC begins to act up. I could just wait for the tell-tale symptoms or the two beep warning and then change it out. However, the boat is entering its 8th season of service and has 330 hours on it. Most IAC's on 496's are lucky to go 200 hours. I've seen several posts, this one included, where by the time you get the beeps or the motor starts to not want to run at idle damage may have already occurred to the wiring. That is the only reason I am considering changing it out before it goes bad.
Old 05-31-2012 | 01:48 PM
I guess if the IAC's on 496's have a bad track record, and you've ready spent the money then call it preventative maintenance. Just wondering if the valve portion becoming sticky strains the solenoid part??? Most automotive applications have adaptive learned strategies to overcome engine aging issues. Just make sure all your connections and grounds are clean and secure...
Old 05-31-2012 | 03:12 PM
Gasket number F7UZ-9F670-AB, wire kit number is WPT-357, did not check that as for now I don't need it.
BlueOval is offline
