Need some advise >
Need some advise
Need some advise
Old 05-31-2012 | 09:14 PM
Default Need some advise
I have 2007 26 Outlaw 496 HO 425 hp and when I purchased this boat the prop was missing. They put on 23p 3 blade, turned to rev limiter and only 57 mph. Up graded to 25 pitch 3 blade Power Tech 61 mph @5100 rpm. told this should go faster?
26outlaw Dave is offline
Old 06-01-2012 | 12:00 AM
You are in the ballpark with that boat...they run 62-66 MPH with 496 HO. I would test a few other props to see which one you like best but your very close on speed.
Baja_man is offline
Old 06-01-2012 | 05:40 AM
What brand was the 23p prop? These boats come from the factory with 23p mirage + props (at least I know 25OL do, I'm assuming 26OL do too) I would try that prop first!
Fordtough150 is offline
Old 06-01-2012 | 11:37 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Testing a 25 Mirage + to obtain a base line for Lab Finishing is the best go fast option.
We can help with that if you desire.
Brett
[email protected]
bbladesprops is offline
Old 06-01-2012 | 11:39 AM
Thanks for replying and thinking of trying 24 pitch bravo one.
Old 06-01-2012 | 11:53 AM
Try every prop you have the oportunity to try. If you like the B1, it can be modified to decrease the stern lift it will have.
Brett
[email protected]
