38 full staggered hard to plane!  ?? spacers? >
Old 06-03-2012 | 07:06 AM
Default 38 full staggered hard to plane! ?? spacers?
07 38 lightning 525's xr's sportmaster its gimbals. Drives are little higher for top end- having hard time getting up on plane -running 7 blade herrings- i did just have botttom of boat waxed- on board 4 guys w/average weight of 225 pounds and 3/4 tanks of fuel. any suggestions?? i was told that spacers are going to kill top end! how much? thank you
ratedx is offline
Old 06-03-2012 | 07:53 AM
When you say a hard time, are you blowing the props and cavatating or having trouble getting rpms out of those 7 blades out of the hole?
4bus is offline
Old 06-03-2012 | 11:20 AM
yes-blowing props and cavitating!
ratedx is offline
Old 06-03-2012 | 05:15 PM
TRL505's Avatar
Higher X = sacrificing hole shot. A 1/2" spacer would help....but more than likely will affect top end by a few MPH. How far is center of propshaft above/below bottom of boat?
Maybe R3 will chime in here..
TRL505 is offline
Old 06-03-2012 | 06:59 PM
according to test run x-dimension is 22 1/4 x 18 1/2 - is that info any help?-i have no problem sacrificing 3-5 mph to help get up on plane test sheet =97mph.
ratedx is offline
Old 06-03-2012 | 07:40 PM
getting on plane is a little differant than a side by side, once you've done it a couple times you get used to it.
JMPH is offline
Old 06-03-2012 | 07:48 PM
what size spacers should i use? i was out for first time-got it to plane once but after that could not get it again-any suggestions on where to purchase??size??
ratedx is offline
Old 06-03-2012 | 09:40 PM
you could put extended hubs on the props that you have now. or you could try a different set of props like some 5 blade maximus if you're not concerned about the top in number being a few miles per hour slower
mcprodesign is offline
Old 06-04-2012 | 05:07 AM
props that have been used in the past have thrown blades-because of high x dimension! these 7 bladers are the only ones that stay together. What size spacer? brand?
ratedx is offline
Old 06-04-2012 | 12:25 PM
TRL505's Avatar
Did you try this:
1. Drives tucked and tabs at 5.5-6
2. Run boat up to approx 3200-3500 rpm's...it should still be hooking and gaining speed and beginning to try to plane.
3. As boat picks up speed (17-19MPH) gradually start bump up tabs till it breaks over....gradually apply throttle to about 4000rpms till it fully breaks over and hooks.
It takes our 42 a LONG time to get up on plane...lol.
TRL505 is offline
