Wheel bearing grease removal.... >
Old 06-06-2012 | 08:51 PM
Smitty's Avatar
Default Wheel bearing grease removal....
I need to repack my trailer wheel bearings. I would like to remove as much of the original grease from the bearings and repack with higher temp synthetic grease. Question is what is the best solvent to use ?? I am at home and have air to dry them out with. I have some pans I can fill with what solvent ????
Thanks !!!
Smitty
Smitty is offline
Old 06-06-2012 | 09:27 PM
we use break cleaner
Perlmudder is offline
Old 06-06-2012 | 10:37 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Used gas ever since I was old enough to work on cars some 30 yrs ago. Always gas sitting around.
US1 Fountain is offline
Old 06-06-2012 | 10:40 PM
Paint thinner works well also.
f_inscreenname is offline
Old 06-06-2012 | 10:42 PM
How do you get the bearing buddys off?
jrdonnellyjr is offline
Old 06-06-2012 | 11:03 PM
tap with a hard plastic hammer as you spin the wheel
mr3dman is offline
Old 06-06-2012 | 11:09 PM
Your over thinking it,just put the new **** in. Wont be a problem as long as the bearings have lube
JJONES is offline
Old 06-06-2012 | 11:17 PM
I use mineral spirits and a small paint brush cut short to poke and clean them out. Then use air hose to blow them dry into a empty case of beer box.
A very mild solvent that doesn't small so bad on the hands later.
paulb32 is offline
Old 06-07-2012 | 10:36 AM
+1 on the gas. That is how I've always done it.
Chico&Zeus is offline
Old 06-07-2012 | 12:19 PM
seltzer's Avatar
I enjoy emptying the case of beer part.
seltzer is offline
