383 stroked in a 96' Tantrum? >
Old 06-07-2012 | 04:36 PM
Default 383 stroked in a 96' Tantrum?
So I had a little bit of bad luck and my motor went last week. Im thinking of replacing it with a 383 stroked to save a couple bucks. My thoughts are it has more HP than my 330 did and will get alot more rpm's out of it. What are you guys thoughts?
carreraboy1 is offline
Old 06-07-2012 | 08:29 PM
I think you would be better off going with more cubic inches. There are a lot of used 454 motors and maybe find a 502 which is more expensive but will get you to the 60+ mph easily.
HavinATantrum is offline
Old 06-08-2012 | 04:42 AM
REMEDY's Avatar
Yep, get a big block. That small block won't do it.
REMEDY is offline
Old 06-08-2012 | 04:25 PM
Big block's generally make more torque, that is what will move the boat. You will also have the cost of new manifolds to thinly about
My Addiction is offline
Old 06-08-2012 | 09:17 PM
Stormrider's Avatar
JC Performance Engines
Buy both of these for 10k and keep one as a spare.
http://www.offshoreonly.com/classifi...o44621-en.html
Stormrider is offline
Old 06-09-2012 | 12:54 AM
Putting an SBC in it would be like putting a V6 in a Corvette.
Griff is offline
Old 06-09-2012 | 01:18 AM
Then again I remember when a V6 S10 Syclone pickup or V6 Regal GN sedan would eat a Corvette for lunch..
I say do it and see what happens.
HTRDLNCN is offline
Old 06-09-2012 | 08:12 AM
I have a 454 fresh machined 30 over. needs a set of pistons. cheap....and here on LI
carrera1 is offline
Old 06-09-2012 | 11:38 AM
The intercooled turbo chargers on those gave them the power and torque.
Griff is offline
