Go Back  Offshoreonly.com > Owners Forum > Donzi
Fuel range in a 28zx >
Old 06-08-2012, 06:27 PM
Default Fuel range in a 28zx
I have a 2001 28 zx with twin 350 mag mpi power. Running completely stock mercruiser risers, corsa exhaust, bravo 1's with 1.50 ratio, and mirage 23p's).
I havent taken it on a long journey yet, but would like to try out lake erie, going frosay, Geneva on the Lake to Cedar Point.
I saw someone post 3mpg on a similar boat. Is this realistic? I have a 94 gallon tank. Cruising at, say 55mph.
Thanks!
Mike
Shag555 is offline
Old 06-09-2012, 06:44 AM
3 mpg sounds pretty high to me, I used to get around 1.5-1.7 mpg cruising at about 3300 rpm on my old boat with a 350 mag. Your probably safe figuring 150 mile range, and more than likely end up with about a 220 mile range, ive never really seen any boat with less than 150.
GoFastScott is offline
Old 06-09-2012, 10:02 AM
Awesome... Exactly what I was looking for. Thanks!
Shag555 is offline
Old 06-23-2012, 04:58 PM
Default fixx
Thanks!
Mike
find yourseld a pair of 22p revolution 4 bladers..thease will give you way better fuel economy..my buddy burned 1/3 rd lass fuel with his 292..
FIXX is offline
Old 06-26-2012, 10:56 AM
I get just about 3 mpg, fishinSucks gets 3 mpg. The hulls are pretty efficient.
If you manage less than 2mpg you are doing something wrong.
VetteLT193 is offline
Old 06-26-2012, 01:03 PM
Vette is right on. With my twin 350 mags, 1.5:1 ratio, 23p Mirage plus 3 blades, in a 92 mile round trip with about 6 slow-downs I burned 33 gallons cruising around 55-60 and some WOT moments. during that same run, our friends with a 2000 28zx, same set up and a 28zx scorpion burned 35 and 37 gallons respectively. they were also doing more wide open running than us. Enjoy Lake Erie, it's a lot of fun. We've been to Put In Bay many a times and Cedar Point as well with our 28ZX, fun times.
tom
FISHIN SUCKS is offline
Old 06-26-2012, 03:49 PM
Registered User
I see where you have a 2008 28 ZXO and was wondering what engines, and props you run. Speed? Etc.... I have 07 with twin 6.2's and 25P Mirage Plus 3 blade props. Been thinking about switching to four blades, but would like some input from other owners of the 28 ZX or ZXO.
Oh, and sorry for high-jacking thread..... Hope you dont mind my question.
BradmanVA is offline
Old 09-17-2012, 01:21 PM
vette131's Avatar
what rpm's are you guys cruising at to get 3mpg? running 4000 rpm's I burned 57 gallons on a ninety mile trip with a few wot moments.
vette131 is offline
Old 09-17-2012, 03:12 PM
I would guess youd have to run at 3500 rpm - right at easy cruise. I did 62 miles and used 45 gallons.
Shag555 is offline
Old 09-17-2012, 03:13 PM
That was at WOT most of the way...
Shag555 is offline
