Repairing outdrive gear case chip? >
Old 06-08-2012 | 07:26 PM
Default Repairing outdrive gear case chip?
I currently have a chip about the size of a silver dollar on the lower gear case (Alpha One) right on the fin at the point were the lower housing meets the upper.
My question is to what options would I have to repair this and make it look as unnoticeable as possible?
Obviously a new lower gear case would be best but is not cheap.
Weld (TIG) a matching piece in place but would take grinding the weld and possible filler and paint to be unnoticeable. I know that the paint will probably not hold for very long.
The gear case does not have a hole in it just on the external fin.
Any suggestions??
Mariah212Z is offline
Old 06-08-2012 | 07:40 PM
try JB welding a piece in. stuff is pretty tough. i hit a curb with my car automatic trans. knocked out a hunk about same size. all the tranny fluid fell out. found the chunk, cleaned it up with acetone and JB'd it back in. 6 months and counting...you can also lay a larger piece underneath and glue-clamp it on. then bodywork it out. (i think they call it fairing when it is marine, sounds better than bondoing.)
dereknkathy is offline
