Gen 5 to Gen 6 flywheel ??? >
Old 06-10-2012 | 08:19 AM
Default Gen 5 to Gen 6 flywheel ???
Swapping out gen 5 454's for gen 6 502 blocks. Anyone know if the flywheel is the same or do I need to buy new ones?
Baja226sport is offline
Old 06-10-2012 | 11:50 AM
Should be the same.
picklenjim is offline
Old 06-10-2012 | 12:26 PM
If they were the low hp 454MPI's with cast cranks then it's a different flywheel. The 454MAG uses the same forged crank and has the same flywheel as the 502. There is an extra counter weight cast into the cast cranks so it takes a slightly different flywheel. If they're the wrong ones, any good machine shop should be able to balance them to the GM502 specs for cheap.
HaxbySpeed is offline
Old 06-10-2012 | 09:09 PM
Is there a # on the flywheel I should look for to know exactly what I am working with?
Old 06-10-2012 | 10:01 PM
You need the flywheel with casting # 805. The 805 will be on one side and the other side will have an 8 digit # ending in 805.
Eddie
Young Performance is offline
Old 06-11-2012 | 08:38 AM
Thank you very much!!!
Old 07-21-2012 | 05:56 AM
Well I guess 1 thing is going my way. 805 on the flywheels! So I guess these are what I need then.
