454 oil pump pick up
hi guys
My engine has eaten it's big end bearings and the oil pick up has caught most of the big debris and collapsed the screen so I need a new pick up tube.
I have had a search through the forum but have come up blank.
Do you know who makes a direct replacement for a 454 Alpha oil pick up tube as they are now made of unobtainium!! the sump is standard 8qt i think.
TIA
TIA
hope you went completly thru engine, replaced oil cooler and flushed oil lines very well...or the pickup going to be the least of your worries....I think a std GM pickup will work fine..that 8qt pan is stock depth just longer
gen V or VI look up 1992 gmc suburban 2500 with a 7.4l engine..that engine holdsa 8 qts of oil..if its a mark motoe look up 1988 gmc supurban 2500 7.4l engine,that one also holds 8 qts of oil..BTW both have to be four wheel drive.
