starboard K-plane not working >
Old 06-13-2012 | 04:55 PM
Default starboard K-plane not working
Went out this past weekend and noticed the starboard k-plane would not work. Opened hatch and hit the switch.....nothing. pump doesn't even come on. I could spend all day looking around, but can anyone help give some pointers to troubleshoot the system?
rumrunner29 is offline
Old 06-13-2012 | 07:36 PM
I had an issue just as you described. There is an inline fuse in a yellow rubber jacket by the trim pump that I opened up and cleaned up the fuse and it went back to work and no problems since. Maybe a slight amount of corrosion that interupted the connection. Hopefully it is that easy. Good luck!
4mulafastech is offline
Old 06-13-2012 | 09:03 PM
Wish it could have been that easy, tried that earlier and still nothing
Old 06-13-2012 | 10:30 PM
Sydwayz's Avatar
Forum Regulator
Any clicking or anything? There are two solenoids, one for up, one for down. They do go out, but usually not at the same time.
Also, check the back of your switches. Sounds like you may have an open, broken wire, disconnected, corrosion, etc. You may have to ohm out the wires.
Sydwayz is offline
Old 06-13-2012 | 10:44 PM
mine are on circuit breakers under the rear bench seat(formula) dont knoe if you have a similar set up..
FIXX is offline
Old 06-13-2012 | 11:03 PM
Nope, no click or anything..I'm gonna pull the switch plate up in the morning and go from there. Not sure where the problem is, it doesn't work from either the starboard switch or the BOTH switch. Port tab works fine.
Old 06-13-2012 | 11:21 PM
onesickpantera's Avatar
Check the ground wire and if its good put 12 volts to the larger blue or green wire. If it doesn't work its your motor. If it does check the voltage at the other side of the selenoid(red wires) and work your way to the dash. I had a k-plane quit and it was a dead spot on the armature. I had a good ol boy that rebuilt starters fix it for like 30 bucks.
onesickpantera is offline
Old 06-14-2012 | 09:02 AM
Smack the motor with a piece of wood. (Tap test) Mine did the same thing 5 years ago and arcticfriends hit it and it has worked fine ever since. True story.
Old Navy is offline
Old 06-14-2012 | 06:47 PM
jumping the 2 solenoids is another back yard smoke test if neither work, most likely culprit is lost 12v or lost ground...
dereknkathy is offline
Old 06-14-2012 | 07:21 PM
Thanks for everyones help, I ran a jumper wire back to the pump and it worked, checked the switches and they were all fine. Didn't have 12 volts at the pump, so I traced the wires and found that the 12 volt power wire runs from the batt switch to the drive trim pump and then runs from there to the k-plane pump. Well, where the line comes off the drive pump there is a fuse holder WAY down by the starter and this fuse was blown. Changed the fuse..BINGO! works fine now..
Thanks again for the help
