525EFI factory headers on 496HO?? >
Old 06-14-2012 | 08:32 PM
Default 525EFI factory headers on 496HO??
Can you fit factory 525EFI CMI headers on 496HO's? I found this thread about putting 496 CMIs on the 525... http://www.speedwake.com/forums/showthread.php?t=60902 ...but nothing on the opposite. Drilling new holes to fit the header on wouldn't be an issue, but I have a feeling they wouldnt line up with the corsa q&q... And I will need it boating in certain areas of Michigan. I posted on Q&A but seems that gets little traffic. Any help would be appreciated. Thanks-
AJ
AJ POWERPLAY is offline
Old 06-14-2012 | 09:40 PM
I don't know the anwer to your question. But you may want to do a search for the issues that the cmi 525 headers have with leaking. There may be better choices.
raytart is offline
Old 06-14-2012 | 10:58 PM
Would be buying them from a friend, they would be sent to CMI and pressure tested first... But I know what you mean, the Dana marine headers seem to be a good value
Old 06-15-2012 | 12:45 AM
c_deezy's Avatar
Why would you want to in the first place? The 496's don't need them, so why bother with the hassle?
c_deezy is offline
Old 06-15-2012 | 02:11 AM
Full throttle marine did back to back dyno pulls with and without aftermarket headers, gained 25-30hp with Dana headers... Plus they look cool which adds like 50 hp
Old 06-15-2012 | 06:34 AM
Indy's Avatar
Member #154
I wouldn't get near anything CMI makes...they lost the trust of many on this board with the crap they pulled.
Indy is offline
Old 06-15-2012 | 07:25 AM
Talking
50hp cool factor. You have to love that.
akaboatman is offline
Old 06-15-2012 | 07:26 AM
Knot 4 Me's Avatar
If the motors are going to be otherwise stock, stick with the stock exhaust.
Knot 4 Me is offline
Old 06-15-2012 | 08:52 AM
On paper people are showing big power gains. In real life you will not see it. BTW, you can pressure test them yourself in a water tub and regulated compressed air. I put CMIs on a stock 496 and saw ZERO gain in anything except looks.
thirdchildhood is offline
Old 06-15-2012 | 09:39 AM
was thinking about having whipple do the stage 2 tune and adding headers... was hoping for 2-3 mph (twin engine setup)... we will see, maybe I'll have to do some prop work with Bblades as well, headers would be last though.
