525sc dominator 1050 carb question >
Old 06-14-2012 | 10:32 PM
Default 525sc dominator 1050 carb question
I need to know if the stock 525sc gen 6 carb (dom 1050) are already boost reference? I dont know how to determine if it is or not boost reference.
Also what is the right procedure to determine if you have the right PV on a boat engine?
supermx96 is offline
Old 06-14-2012 | 10:43 PM
I may be wrong but i thought boost reference only matters in a "blow through" application......
gofast540NY is offline
Old 06-14-2012 | 10:50 PM
Default fixx
if it were boost referanced it would have a vacume port on it for a vacume hose that would go to the intake..
also see if it has 3 air bleade jets per ventury or 2 air bleeder jets..
FIXX is offline
Old 06-15-2012 | 01:48 AM
Not boost referenced and I don't feel its needed for them. They run like an efi when properly adjusted.
The stock 6.5PV's work just fine in them. I had a bigger roller cam and was running almost 8# of boost and it idled and ran perfect.
Griff is offline
Old 06-15-2012 | 06:37 AM
That is for an upgrade 525sc with aluminum and b&m 250 blower and now i am in tuning of that engine and dont know if it need to have a boost reference carb. What is the right way to test if you have the right power valve?
I will take some A/f ratio # this week end see if i am ok
Old 06-15-2012 | 06:43 AM
blue thunder's Avatar
If you have a boost/vacuum gage on the dash, note what vacuum you run a cruise speed the select a PV.5-1 in less in vacuum. I run 5-5-5in vacuum at cruise so I run a 4.5in pv.
I also validate with my A/F meter to ensure it is not getting too lean before it opens. Thats the best way to do it.
blue thunder is offline
Old 06-15-2012 | 08:21 AM
That works ONLY if its boost referenced. The standard 525SC merc is not. Like griff said 6.5PV.
If you wanna be safe, you can put a 8.5pv. Only way to really check is either have a vaccum gauge under carb, but on top of blower. This is where the PV gets its signal from.
MILD THUNDER is offline
Old 06-15-2012 | 08:23 AM
Boost reference the fuel psi regulator in a blow thru app.
Old 06-15-2012 | 09:28 AM
I have the vaccum gauge that i can plug under the carb (on top of the blower) do you chek vaccum in drive at idle to determine the pv ?
What calculation +or- of the vaccum # ?
Thanks.
Old 06-15-2012 | 05:14 PM
Default fixx
Thanks.
most boost gauges have a vacume part on the oposite side of the gauge..just install one in your dash to keep a eye on boost pressure..killl 2 birds with one stone..also make sure you have plenty of fuel pressure..at leaste 7 psi..
FIXX is offline
