4" x 4" x 4"  fiberglass exhaust t's >
Old 06-16-2012 | 05:32 AM
Default 4" x 4" x 4" fiberglass exhaust t's
Need 2
open87 is offline
Old 06-16-2012 | 07:40 AM
I have a pair of fiberglass 4" tips with internal flaps that extend out the back 1 1/2" and inside boat 6" from flange. $30 plus shipping from 21009. Also have polished SS 4" tips that extend 3" and also 5" for $150 a pair plus shipping.
boatstogo is offline
Old 06-16-2012 | 08:44 AM
They are needed up at the motor , not at the transom , boat is straight inboards amid ship ,replacing the exhaust hose..
the 90's and the 2 tee's are cast iron
like this --
http://bpi.ebasicpower.com/p/MUFTE-444-2176/Tee+Fitting,+Exhaust,+4+X+4+X+4,+Standard
open87 is offline
Old 06-16-2012 | 02:00 PM
Default fixx
like this --
why do you want to buy used?? they rot after so many years then your boat sinks...
http://www.centekindustries.com/fittings.html
FIXX is offline
Old 06-16-2012 | 02:42 PM
Wow, I was way off on that post. Thought you were looking for exhaust tips. Can't help ya, but best of luck with your project.
Old 06-16-2012 | 06:20 PM
Figure someone may have set that have been sitting on a shelf not used , never know unless you ask ...
She already has stainless tips Thanks though..
open87 is offline
Old 06-16-2012 | 11:11 PM
c_deezy's Avatar
For $100 a piece I would lay up my own.
If you do the layup on the outside using 3" pvc, it would be about 3.5" OD before starting to glass. So you layup the initial tube with a couple layers of glass, then cut them to make/form the T. Then continue doing the layup until you get to the 4" OD that you are looking for.
Here is a pic of how I did something similar for rigging tube. I did two 3" tubes, and the upright one was 1.5" pvc. Just make sure you wax the PVC tube good, then all it takes is a few good whacks on the floor and it will slide right out.
Attached Thumbnails 4" x 4" x 4"  fiberglass exhaust t's-img00049-20100401-1527.jpg
c_deezy is offline
