IMM Boat lifts- Cant use boat! please help!
Just purchased a 13,000 elevator lift from IMM boat lifts also known as Quality lifts. The gearing/motor set up jamms up under a load because the mounting design is soo poorly engineered! The company will not even send out a rep or stand behind it. Ican not use my new 38 fountain! any suggestions??
Are you sure that you have the correct voltage to the motors. I had trouble with mine after we had some dredging done. Turns out that the electrician re-wired from 240 volts to 120. The lift was working very slow and would stall just as the lift would hit the weight of the boat. The motors sounded like a problem in the gear box, but it was just the wrong voltage.
Hope this helps.
I have stopped by Quality over the years to purchase repair hardware. I was just there in March and it looked like the economy has hit them badly.
Hope this helps.
