Go Back  Offshoreonly.com > Owners Forum > Powerquest
Prop rotation? >
Prop rotation?
Prop rotation?
Old 06-20-2012 | 10:11 PM
Default Prop rotation?
I have a 290 Enticer - twin 502's - i run 26 pitch, four blade props
At high speeds it get's pretty loose in boat chop.
My props turn out......
Any thought's, feedback, or opinions?
eriknelson is offline
Old 06-21-2012 | 01:40 AM
That's the unfortunately I've heard this about all 290's, mine did it also, try adding some tab
AJ POWERPLAY is offline
Old 06-21-2012 | 06:18 AM
DRIPPINWETII's Avatar
Try turning them in,the 300's turn in.
DRIPPINWETII is offline
Old 06-21-2012 | 07:17 AM
erick
what kind of speeds are you seeing and what's it like coming out of the hole with those 26s? I thought the 4 blades where more stable than 3 blades yet they cut down on the speed?
I'm running 502s and 23 pitch 3 blades spinning out and the best I've ever seen is 71.5 mph. Mine will chine walk just a little on the top end. Not always though, just gotta find the sweet spot of trim and tab.
Jplanes is offline
Old 06-21-2012 | 08:51 AM
bsc
Keep them turned out, turned in will add bow lift and turned out stern lift. Just got done testing on my 34 Vyper and turned in I was all over the place, turned out right trip/tab let go of the steering wheel.
bsc is offline
Old 06-21-2012 | 09:04 AM
It runs 80 @5000 -
When the props are on the opposite side, doesn't it effect the driveability?
Old 06-21-2012 | 09:16 AM
bsc
With them turning out, I only noticed a more stable ride at WOT. Cruise and docking seemed the same. But I was testing with my shifters in the wrong direction if you know what I mean. A lot of thinking was going on too. 2 nights ago dug into the Gaffrig shifters and changed the linkage for my new turned out rotations. Could be happier.
Turn them in on yours, it’s only a couple nuts. Testing is ½ the fun. Let others know of your findings.
bsc is offline
Old 06-21-2012 | 06:11 PM
i hear yea on the testing thing lol - hitting a wave a 80 scares the crap out of me when it's walking all over lol
we did the change at the shifters, so we have that all accurate - the first time i put it in reverse, and jumped back on the trailer lol
do all Bravo's have left, and right hand props?
