500 efi distributor
Does anyone know the ac/delco part number for the distributor for a 500 efi. We are at the Hartwell poker run and we have lost a distributor. Want to see if I can find one local.
the pickups are generic, the modules are not...should be able to fix yours.. delco EST ? pull module see if you can match #, you can get away with any module in a pinch...but timing curve may not be the same even tough ECM controls it..
It wasn't the distributor after all. It was the weather tight connector that plugs into the control module on the distributor. Does anyone know where I could find these. It's the four wire connector? Is this a plug that I can find after market?
