electric/hydraulic brake issue??? >
Old 06-25-2012 | 06:46 PM
wrinkleface's Avatar
Default electric/hydraulic brake issue???
excessive delay, reasons????
have tried 2 dif brake controllers(underdash & built in 450 Ford)
lines have been bleed, helped some but still way 2 long braking delay
Thanx 4 any help!!
wrinkleface is offline
Old 06-25-2012 | 07:38 PM
Sounds like still air in the system..................
smcser is offline
Old 06-25-2012 | 08:33 PM
Sounds like same problem I was having. Ford manual states there built in controller will not work with a electric over hydraulic style trailer brake system. I went with the activator 2 and since I pump my brakes the delay never seems to catch up. The older style did not have this built in delay and worked much better for my driving habits. The nice thing about installing the older activator 2 with a plug and play wire harness, it only takes a minute to unplug wiring from back of factory controller and plug this one in. With factory brake controller unplugged you will have a trouble on your dash so I do swap the 2 depending on trailer.
Soggy Dollar is offline
Old 06-25-2012 | 08:53 PM
offshoredrillin's Avatar
get the max brake and never worry again.
offshoredrillin is offline
Old 06-25-2012 | 08:58 PM
the newer Titan systems R supposed 2 work w/ the built in, drawtite act 2 & in-dash work'n about the same????????? near 4 second delay, my last trailer came on in about 1/2-1 sec at most!! so much for years newer & technology!!!!
Old 06-26-2012 | 04:40 PM
I can sympathize about the delay problem. Anything over 1 second would be unacceptable to me. My Tekonsha Prodigy (with all electric brake) response is virtually instantaneous. I agree, about the newer controllers, more delay is a step backwards.
Hematite is offline
Old 06-27-2012 | 05:39 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Exactly! You can adjust it to where you don't even know your trailer is behind you.
US1 Fountain is offline
Old 06-28-2012 | 02:31 PM
Lake Rat's Avatar
Get a Prodigy P2. It can run electric, or electric over hydraulic by switching modes. That is what I had in my old truck and it worked perfect with my trailer that had electric over hydraulic. I originally had a Draw Tite Activator II and it had a very bad delay, basically didn't do squat. I installed the P2 and the brakes worked perfect.
Lake Rat is offline
Old 06-28-2012 | 02:39 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I love my Max-Brake controller.
Sydwayz is offline
Old 06-29-2012 | 01:36 PM
Tried the Prodigy 3, same delay!! Scot at NT is have'n the same prob w his Myco under his new boat!!
