47 Lightning Imco SC #6 props >
Old 06-27-2012 | 07:56 AM
Default 47 Lightning Imco SC #6 props
I finally got my drives back and props from Hering. Should be water testing this weekend. Also got my dash panels back from Innotech. Hope this setup works for me. It will definitely work 100% better than the 7 blade Herings and
1 1/4 prop shafts I was originally going to use that would probably end up on the bottom of the ocean with 10 to 15 hours of use. And probably wouldn't been able to get on plane being 2 1/2 inches prop shaft above bottom.
Attached Thumbnails 47 Lightning Imco SC #6 props-47lightningdrives.jpg   47 Lightning Imco SC #6 props-47lightningdrives2.jpg   47 Lightning Imco SC #6 props-47lightningdash.jpg
47 lightning is offline
Old 06-27-2012 | 08:13 AM
why a Bravo in the center?
Griswald is offline
Old 06-27-2012 | 08:30 AM
Whos #6 shaft are those and do they use same carrier?
Pokher Ace is offline
Old 06-27-2012 | 08:38 AM
Finally , hope things work out for you , keep us informed
575cat is offline
Old 06-27-2012 | 08:52 AM
WOW that is frickin' beautifull !!!!
mcprodesign is offline
Old 06-27-2012 | 08:53 AM
A video of it Idleing would be Awesume
Old 06-27-2012 | 09:04 AM
steering plate will not fit imco never had a problem with it .before the xr i was using a xz and it held up
Old 06-27-2012 | 09:25 AM
I hope the drive internals will take the load of those big wheels , are those 17s and what size is the center ?
575cat is offline
Old 06-27-2012 | 09:52 AM
18 x34x18 rake outers 17x35x18 rake center.iam more worried about the ginble rings helmets etc
Old 06-27-2012 | 10:29 PM
sweet pics vids would be better
mikesystem01 is offline
