HP500 PCV Valve
Old 06-27-2012 | 09:25 PM
Default HP500 PCV Valve
Anyone ever replace one with a pcv from pep boys or napa or something? I am just wondering if the merc one is anything special since it goes right into the lifter valley.
Baja226sport is offline
Old 06-27-2012 | 09:40 PM
Ive found there isnt much 'special' parts when it comes to merc stuff, except the price. Like the 600/800SC supercharger belt tensioners i have. list price is 640.00 from merc. Funny, there is a GM # stamped into the tensioner. Looked it up online, about 60 bucks from the chevy dealer. Same tensioner used in the LT1 vette engines. But, it doesnt come painted blue. So if the blue paint is worth an extra 580 bucks to you, then you gotta go merc.
I think you should be safe to take your PCV valve down to pep boys, and match it up.
MILD THUNDER is offline
Old 06-28-2012 | 07:48 AM
I don't have one to actually match it up. I wonder how much difference there is between pcv valves.
Old 06-28-2012 | 08:25 AM
F-2 Speedy's Avatar
I have one, I'll see if there is a part # on it
it looks just like one u would find in a small block valve cover
F-2 Speedy is online now
Old 06-28-2012 | 01:21 PM
Any chance of a picture of it?
Old 07-05-2012 | 04:34 PM
fantastixvoyage's Avatar
I'm in the same boat, have the valve covers but no PCV valves. If anyone knows the generic automotive part number that would be helpful. have a supercharged 502 that were just straight pass thru, no check valve. Seemed to work good but no part # for those either.
fantastixvoyage is offline
Old 07-06-2012 | 11:35 AM
I would recommend you look up in the older GM Performance catalogue for the GM 502 Ram Jet efi engine and use that part number spec. PCV vlave assembly for that engine as it was fuel injected 502 engine with just about the same identical PCV crankcase volume and manifold pressure requirements. It will be a lot cheaper from GM or aftermarket for that engine.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 07-24-2012 | 05:20 PM
Sooooo.........I bit the bullet and ordered 2 of these from Mercury Marine. They are Mercury part #848578. The damn things cost me $15 each and $8 to ship from Mercury to me. So $38 total.....
They are still in the sealed quicksilver bags, funny thing is the PCV valves actually say ACDELCO CV856C on them.
So to everyone else, just go to pepboys or even look on amazon.com....they are $7 each there
Old 09-28-2012 | 09:37 PM
Does AC Delco also make the rubber grommet the valve sits in? Merc # 811553.
242LS is offline
Old 09-28-2012 | 11:20 PM
Default fixx
go to your locak ap place ,,help products make them..
FIXX is offline
