How long are your fuel lines ?
Mine are approx twenty feet. They run from engine to a fuel manifold. Then from there to three separate tanks. I'm considering moving the manifold to the engine room. I don't know if this is kosher. Does the builder want it outside for safety reasons? I'm trying to shorten the lines as much as possible. I have had constant fuel pressure problems since I got this boat, I have added extra fuel pumps, changes filters etc, still have problems. But if there are other's running these kind of lengths, then I will try something else.
Particulars:
Separate 5/8 hose to each engine from manifold
Each tank has two separate 5/8 hoses with separate feeds going to manifold
Engines are 410 hp 502 carbed
Has carter type high performance pump mounted on engine. I have installed a extra pump in series. This gave me more pressure but it would not keep up under way.
Particulars:
