Gaffrig trim switch needed?
I suspect my trim switch is on the fritz, as occasionally the drive won't trim with the switch, but works fine with the trailer switches. I also redid one of the pump solenoids last year.... can't remember if it was down or up.
But I'm also thinking it could be the trim sender/limit pucks, as I just had the gimbal ring etc. out, and had to reinstall the pucks. I installed and adjusted per Merc's service manual, but maybe something's out?
Took it apart (throttle mount), and it looks like a new switch could easily be soldered in.... gonna do some internet hunting to try to source this thing.
Anybody replace this before, or is a replacement with the harness etc., available? Thanks, J
Then, get the square bore of your gimbal ring welded to add material, and then file/ re-machine the square bore until the swivel pin will just insert.
Worked like a charm!
Nope. I cut open the transom plate to access the swivel pin and pinch bolt, like many others have done. Then made a cover plate out of stainless steel. What you end up with, is the design Merc. Should have had in the first place!
