1996 mercruiser 7.4 mpi efi wont go past 2200 rpm >
Old 07-05-2012 | 11:51 AM
Default 1996 mercruiser 7.4 mpi efi wont go past 2200 rpm
The motor starts and idles perfect up to like 2200 rpm , i checked the mech fuel pump that pumps the fuel to the electric pump in the vst tank and when i turn over the motor i can put my finger over the pump out side on the fuel pump and can stop the fuel from being pumped out without using force with my finger, any help would be appericated thanks jimmie
jimmie is offline
Old 07-05-2012 | 05:06 PM
**** can the entire mess mech. pump and VST. you will be fighting these forever not to mention vapor lock issues.. There are countless OSO'ers with same issues.
the perm. fix is the Aeromotive pump, fuel regulator and 100 micron filters off the pump,, return fuel back to the tank and move on.
I'm in process my self too... Its bull sh-t but is what it is.
silent lucidity is offline
Old 07-05-2012 | 05:38 PM
Try cleaning out the water separator first that is typically the problem. Then check the cool fuel if that doesn't fix it.
GTOFFSHORE is offline
Old 07-05-2012 | 08:45 PM
Thank you ill give that a try i did have issues with water getting in the fuel tanks via bad gaskets on fillers
jimmie is offline
also what do you mean but cool fuel how do i check that
jimmie is offline
Old 07-08-2012 | 09:46 PM
ballon78's Avatar
the vst tank has a filter/screen in it, take cover off vst tank clean filter and it prob will be fixed , happen to me last year on both engines withing a few hours of eachother,
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 07-14-2012 | 03:49 AM
thankyou all cleaning the screen fixed the prob , thankyoiu
jimmie is offline
