port needs more throttle then Starboard on take off? >
Old 07-09-2012 | 10:03 AM
Default port needs more throttle then Starboard on take off?
So the boat has allways had the throttles off by about one click. no biggy.
but this weekend, I was havign to give the port motor 2-3 clicks more than the starboard when taking off. after it leveled out it would go back to only needing the 1 click difference to keep RPM's synced?
any thoughts?
mittens is offline
Old 07-09-2012 | 10:13 AM
88Fount33's Avatar
Beak botr
I had a plug fouling that caused this, but it was always off. Perhaps you have one that loads up under acceleration and then clears out when it leans at speed. Eventually you might see that it doesn't clean up and is always off.
88Fount33 is offline
Old 07-09-2012 | 10:30 AM
Hmm could be, i noticed one onf fire up a little black soot, on ahicup where i did not kold the key quite long enough.
thats going to be a ***** to change in that bildge haha.
mittens is offline
Old 07-30-2012 | 11:28 AM
Plugs fixed this. boat runs ALTO better, now.
mittens is offline
