who can knows what broke from watching this video! help! >
Old 07-11-2012 | 05:40 PM
Default who can knows what broke from watching this video! help!
Bravo xr. Side to side movement when moving the skeg.
https://www.youtube.com/watch?v=gxLd...e_gdata_player
THE 288 KID is offline
Old 07-11-2012 | 05:45 PM
onesickpantera's Avatar
Vid is private.
onesickpantera is offline
Old 07-11-2012 | 05:54 PM
Maybe cause I just uploaded it and YouTube hasn't reviewed it?
Anyhow. I can take the bottom of my skeg and move the left side of the drive up and down in the transom ring. Wtf is broke?
Old 07-11-2012 | 06:18 PM
http://www.mercruiserparts.com/Show_...Lever,,,sounds like you better have it looked at,,have someone move it up and down while you inspect it
TWIN-SPINS is offline
Old 07-11-2012 | 06:23 PM
I measured from the bottom of the skeg and I can move the skeg to the left just under a 1/2" inch. Left bushing appears to be mopped.
Thing I can get this weekend out of it?
Old 07-11-2012 | 06:58 PM
Probably the hinge bushing(#4 in the pic). But if you can move it that much it could be a loose hinge pin and/or a wobbled out hole in the gimbal ring. Pull the cap and take a look, should be two phillips head screws. Take note of where the screws line up as the cap is also the limit switch adjustment.
Old 07-11-2012 | 07:11 PM
I got hp set up. Cap has 4 12pt bolts
Old 07-11-2012 | 07:31 PM
Got ya. Take out the screws and have a look.
Old 07-11-2012 | 07:38 PM
http://jrmarine.com/ check out the videos,,,i used jr marine swivel pins kits on my boat last winter,,redid both gimbal rings,,tighten everthing right up like new,,,if you use his kits you dont have to pull the engine,,,let me know if you need a mechanic thats already has worked with his kits,,also search jrmarine for more info
Old 07-11-2012 | 07:46 PM
I need someone to fix it at Boyne thunder on the trailer lol
