Havi Limescale??
Old 07-12-2012 | 07:34 PM
Default Havi Limescale??
I have some white looking film on the outdrives and bottom from it sitting in the water all weekend.. Does this stuff take MPH off the top? It feels kinda chalky like it might be limescale? How to remove it.. Do It CLR the entire bottom? Any help would be great!!
mcprodesign is offline
Old 07-12-2012 | 07:53 PM
Registered User
Hi Chad,
I used to use Vinegar and water. 25% white vinegar and 75% distilled water and it does an ok job of getting the lime deposits off, but a friend recently introduce me to "Hot Sauce". This is a spray on cleaner and it really works well. You can buy it at any of the boating supply shops, it costs about $18.95 for a 1 quart spray bottle, and you can buy a gallon for about $50.00. Works great, and doesn't take the wax off like the vinegar does. I like it much better than the vinegar trick.
Dave
Dkahnjob is offline
Old 07-12-2012 | 08:07 PM
I've found that Bio-Kleen has a product called Oxidation Remover that works amazing on removing that.
RaveWavesDETAIL is offline
Old 07-12-2012 | 09:56 PM
RollWithIt's Avatar
Slimy Grimy makes a nice hull cleaner as well that wont damage the metal parts. You can get On & Off at west marine but be carefull using it. It will damage the paint on a trailer and will turn black plastic parts white. Its some nasty acid but will clean the thickest crap off a hull.
RollWithIt is offline
Old 07-17-2012 | 08:59 AM
T^hanks for the replies. It's hard to keep a 40' boat clean !!! lol
Old 07-17-2012 | 09:09 AM
Indy's Avatar
Member #154
I loved that stuff, I just hosed down my trailer and kept the hose close when I was using it, if there were any drips I just shot it real quick. I haven't used any of the other stuff but that On/Off was fast.
Indy is offline
Old 07-17-2012 | 12:24 PM
Havasu Hangin's Avatar
CLR or Lime Away works good on that hard water.
Something you may want to consider- Are the drives getting hot?
My boat sat in that water for 10 days without buildup.
Havasu Hangin is offline
Old 07-17-2012 | 06:16 PM
Maybe it has something to do with being there April. My splash plates and everything so I know it's not heat. You headin out the for Labor day?? Chad
