TRS Casings..Suggestions >
Old 07-15-2012 | 11:57 PM
Default TRS Casings..Suggestions
I have an 87 Formula with TRS drives that I bought recently and am slowly restoring while using..the casings were painted with bottom paint (hillbilly prior owner) so I soda blasted them on the boat in hopes Id find them to be in descent shape enough to do a quick prime and paint for the season..although they look much better they do have pitting and some scag damage..I was planning on pulling the outdrives this winter to refinish and will most likely pull them apart and rebuild as well since they are off..that being said does anyone know where I could get casings in better shape or would you suggest repairing refinishing myself (have heard of guys using epoxy type body filler to smooth and restore) or does anyone know of a good place that would do it for me in the Cleveland to Port clinton area?
DYVMASTER is offline
Old 07-17-2012 | 09:10 PM
Anyone? Bueller.....Bueller!?
Old 09-22-2012 | 07:09 AM
Full Force's Avatar
I used body filler on my old TRS's from the Baja, I also used imron paint and they held up great for a few years, I also racked the boat so they never sat in water..
Full Force is offline
Old 09-22-2012 | 07:37 AM
So there is hope yet..thanks FF
Old 09-22-2012 | 10:15 AM
Full Force's Avatar
Depends how bad they are, the TRS is known to split the lower case when weak, I would check that out, if they are corroded around spanner nut then I would start shopping now....
Old 10-12-2012 | 11:44 AM
oreo11zeus's Avatar
Default Upper case
I have two very nice upper cases for sale - Make me an offer - also have a couple spares TRS DRIVES COMPLETE - one with nosecones and one set without - http://miami.craigslist.org/pbc/boa/3331172343.html
oreo11zeus is offline
Old 10-13-2012 | 06:39 AM
Lil red has a few sets of TRS's he is trying to sell. They are getting cheaper these days, but the youngest case is 25 years old. At least they used TRS'S in your boat. Most 87 boats are Alphas.
dereknkathy is offline
Old 10-13-2012 | 07:51 AM
DYVMASTER, how did the soda blasting work? I'm thing of taking the lower units off this winter to repaint them, how big of a mess does it make. Did you rent the blaster?
Full FORCE, what are all the steps for applying IMRON paint?
s022mag is offline
Old 10-13-2012 | 08:00 AM
Full Force's Avatar
I sanded my drive es....used urethane primer and sanded again... sprayed imron.... simple as that....
They held up great!!
Old 10-13-2012 | 11:51 AM
Is that in a can or thru a compressor. Did you sand it all the way down to the casting?
s022mag is offline
