5 blade for midrange performance? >
Old 07-16-2012 | 06:25 AM
Default 5 blade for midrange performance?
I spoke w/Cutting Edge props in California about maximizing mid range performance on my 30' w/mag HO's and his recommendation was to use a 5 blade, down 1" in pitch and maybe a little tuning to get the max RPM is line. Agree...disagree.
miwettig is offline
Old 07-16-2012 | 06:38 AM
mrquad1's Avatar
agreed,i run 5 blades love them.little off of top end but never blow them out,also they hook up great when re-entering water!
mrquad1 is offline
Old 07-16-2012 | 06:41 AM
Agreed, 5 blades are more efficient, especially noticable at cruise speed.....less rpm to maintain the same speed as 4 blades.
Everytime you add a blade, you drop a degree of pitch.
I just had Cutting Edge work my Hydromotive 5 blades with excellent results.
I have not tried their own design of props but will definately do it in future applications.
verbi69 is offline
Old 07-16-2012 | 06:49 AM
Should I go w/stock 5's for everyday and have the 4's I have now labbed for special days or go 5 labbed for everyday?
miwettig is offline
Old 07-16-2012 | 02:09 PM
I'm thinking stock 5 blades will work, really no need to Lab them.
Having said that one thing to keep in mind is that the 5 blades will add a small amount of stern lift, which may effect handling as you know it with the 4 blades. (It may not be dramatic)
The best solution would be to have the props tweaked with some cup to help pull the bow up a bit and offset the stern lift.
I'm sure the professionals will chime in.
Once the 5 blades are set up you will leave the 4 blades on the shelf, night and day hole shot, mid range cruise and punch...just my 0.02....
verbi69 is offline
Old 07-16-2012 | 02:47 PM
Maximus?
miwettig is offline
Old 07-16-2012 | 02:56 PM
t500hps's Avatar
21 and 42 footers
Agree.......I dropped slip down to 10.5% when I went to 5 blades. I had been running 32P 4 blades for years and made it about 25 hours with 5 blades and lost a drive. Sold the boat soon after (coincidence) and the new owner lost a drive about 25 hours later. They have better mid-range because they bite the water much better. If you surface them and have too much power you are more likely to break something (I made 700 ft/TQ full dressed)
t500hps is offline
Old 07-16-2012 | 03:00 PM
going to 5 blades cost you a drive??
miwettig is offline
Old 07-16-2012 | 03:29 PM
32hustlin's Avatar
Registered User
I just drank the cool aid and ordered a set from cutting edge well see how they work I already had good slip numbers right around 9% not super concerned about all out speed just safety and drive ability
32hustlin is offline
Old 07-16-2012 | 03:35 PM
keep me in the loop w/your results. How do work 'slip' numbers?
miwettig is offline
