full imco hydraulic steering
i just put full hydraulic steering. I have a question, Is full hyfraulic steering alot different then a steering cable in performance. I mean manuverability. When I had it out and trying to dock it, It felt like i was wrestling a cow and the steering would let loose alittle and jerk. What is normal to expect from full imco hydralic steering.? is it smooth at all speeds or jerky at parking and docking speeds?
what should i expect from this type of steering?
im guessing air as well,,,,,,,go lock to lock several times to bleed system and see if it improves.
make sure resevoir is full first obviously
I want to live in a world where a chicken can cross the road and not have its motives questioned.
That is what I thought. The other mechanic said he would put fresh fluid in it and make sure it is corrected. For $3700 it better be smooth. I would turn when docking and it would get stuck and then and then i would force it alittle and it would let loose alittle, I would try cranking it all the way in one direction and that is what would happen. I hope it is the air in the line.
i just put full imco on and love it. i have to wonder if you could be having a pump issue, maybe not supplying enough pressure? i only spent about 10 minutes getting the air out of mine and its been good since.
