Power steering from both engines?
I have twin HP500EFI engines....and like every other setup I've ever seen, I only have one power steering pump.
Why is that?
When there is a failure that dictates I shut down the engine with the power steering pump.....why can't I switch some values and use the other engine for power steering (I mean having dual pumps with a switch over capability).
Thanks for the insight.....
-Steve
Why is that?
-Steve
It is possible to do, there are a couple of different ways to do it. Here are some previous threads that touch on it.
http://www.offshoreonly.com/forums/g...ity-valve.html
http://www.offshoreonly.com/forums/g...-steering.html
http://www.lathammarine.com/st1b.htm#1
take a look at your power steering pump and the crank pulley for other motor. many have room to run a belt between them to get you home. but you hafta have it measured and on board ahead of time! of course, once you do that, you will never need it...
I highly doubt you'll find a way to get a belt from one engine to the other. My boat has a tee at the filter both pressure lines feed, and a tee in the return line before the coolers, separate cooler each engine. Works fine no valves no problems
Work on a lot of paramilitary trash. Done dual pump set ups. You need to put T valves on each side so that the pump can either go through the power steering system or be shunted back to it's own reservoir and use only one side at a time. Just using Ts and hooking everything together is a good way to loose your hydraulic oil. Scenario runs one engine dies and when the fluid exits the power steering system it still goes to both tanks but the dead side isn't pumping it back into the system so after a while the oil over flows from the tank vent.
I have pumps on both engines. Flow is downhill from large overflow/reservoir to first engine (T on top of cap) to second engine. No issues. I have #6 drives - no way to turn those beasts with out power!
