Best drive shower Bravo X? >
Old 07-18-2012 | 09:01 AM
Default Best drive shower Bravo X?
Since I am upgrading my drive to a Bravo X, I am unsure if my current drive shower will fit (Bravo 1) since the new drive is a swept back unit. What is the best drive shower out on the market? I have looked at the drill-less twin pick up from driveshowers.com, any input would be great.
stopdropanroll is offline
Old 07-18-2012 | 08:44 PM
If you are upgrading to a BravoX , make sure you have the correct gimbal bearing and spacers in the trim rams.
As for drive shower, what one do currently have?
1BIGJIM is offline
Old 07-19-2012 | 08:47 AM
Drive and upgrade kit (spacer & Gimbal bearing) are on its way. I am not sure what current shower I have as it was on the boat when I bought it, never seen one like it before. I ended up buying a Halo from driveshowers.com.
Old 07-19-2012 | 10:19 AM
onesickpantera's Avatar
I just helped a friend switch from a standard bravo to a X and he used this shower.
http://www.hardin-marine.com/p-11567...ng-shower.aspx
His Imco steering made his options limited.
onesickpantera is offline
Old 07-19-2012 | 02:16 PM
J.B. Marshall's Avatar
JB Marshall
I just had two new X drives installed last month and used the same drive shower from my Bravo 1 drive. Attaches to the top of my Lathem steering plate.
J.B. Marshall is offline
Old 07-19-2012 | 03:45 PM
I think most of the sweptbacks have the finned top cap.
Old 07-19-2012 | 09:51 PM
you will like the simrek halo, i've tubed behind my boats and can tell you it dumps twice the water that the cap syle does, old boat had the imco setup, also the simrek does clear the drive cap for imco steering
blownhammer2000 is offline
Old 07-20-2012 | 08:30 AM
It clears the rear IMCO cap?
Old 07-21-2012 | 09:13 AM
yes, i had to elongate the hole in the mounting flange on top for the cap bolt, it was tight but i made it work
Old 07-21-2012 | 09:38 AM
My rig has Simrek also, no problems.
Pwraddr is offline
