29 Fuel Gauge >
29 Fuel Gauge
29 Fuel Gauge
Old 07-07-2002 | 02:09 PM
502KC
Default 29 Fuel Gauge
Is it just me, or is the fuel guage fairly inaccurate on the 29 Fever.
My 2000 reads just below half with about 40 gallons left. What has been other 29 owners experiences?
Old 07-07-2002 | 03:12 PM
rjcardinal's Avatar
I have the '99 27 but mines erratic also. It stays full for a long time then as soon as it comes off of full it starts bouncing on empty. I have filled up as soon as it starts bouncing on e and only put in one half the tank capacity. I am kind of learning the gauge now. I have run it on e for a while but always had fuel. This last trip I ran it untill the needle stayed on e and quit bouncing at all and when I filled up I had 15 gallons left. This is about as far as I will push it. While on plane I just hit the gas then pull it back to make a wave in the tank. If the nedle does not move I need gas. Just installed my GPS so now I will have a trip meter to gauge fuel consumption also.
Hope this helps,
Ron
rjcardinal is offline
Old 07-07-2002 | 06:40 PM
All the Fountains (and probably others) have this problem. The tanks are long and low and the senders are in the rear. The boats sit at a fairly high angle and this keeps the fuel "full" at the sender for a long time even though it's getting low. You need to kind of keep track of your fuel. When the gauge says 1/2 you probably have 1/4 or less. My 47 still shows full on the tanks when actually they are less than half!
innthered is offline
Old 07-07-2002 | 07:57 PM
candyman35's Avatar
The GPS is the only way to track the gasoline usage. I average 1.5 mpg. I have had my boat run out of gas. And for those wondering a 35 classic will not stay on plane with one engine! My gauges read a quarter of a tank and still bounced. I knew from my mileage calculations that I should have 15 gallons per tank. Wrong! Fountain used smaller tanks for part of the year in 1997. Guess who had the smaller tanks. :eke: I had always thought they were 79 gallons, they were 69 gallons. I also found out the pickups don't go to the bottom of the tanks there is 4-5 gallons of unusable gas. This means rjcardinal had less gas than he thought. When I filled the boat it only took 64 gallons and 63 gallons.
Dan
candyman35 is offline
Old 07-07-2002 | 08:43 PM
On our 93 42...1/4 tank on the guage means 5gal or less!
Back4More is offline
Old 07-07-2002 | 10:26 PM
envision
Reggie sends a video with the new boats. It says that 1/2 a tank on the gage is really a quarter and 1/4 is only 5 gallons.
Today I started with 1/3 and added 33 gallons and ended up with a full tank.
It goes down that fast too.
Old 07-08-2002 | 07:59 AM
Jana's Avatar
A little under half is empty on mine. All the way back from Stingaree's (across Galveston Bay) a few weeks after I got her, it was sitting at half and I was wondering if I had enough gas to get back. She ran out right in front of the marina - darn gauge still said about half a tank.
Jana is offline
27shooter
5
09-18-2007 09:39 PM
Steve_H
4
02-03-2007 11:58 PM
ComfortablyNumb
5
05-22-2006 10:20 PM
snopro13
6
05-12-2005 01:25 PM
JROMY
2
07-23-2003 07:29 AM
