tilt/trim pump
Old 07-24-2012 | 07:30 AM
Default tilt/trim pump
I took the boat for a run on saturday, had a problem with the tilt/trim,,, the drive went down and wouldnt go up. The Boxer was goin in and earnie lent me some tools to remove the pin and got the boat home. I need a trim pump, does anyone have one to sell used? this probably is not the area on OSO to be looking for parts, butt,,,, any ideas would be greatly appreciated its for a Bravo one drive
jim
fishermanjm is offline
Old 08-03-2012 | 10:18 AM
Sick Stinger's Avatar
Brotherhood #1
Do you still ned a pump?
Sick Stinger is offline
Old 08-03-2012 | 10:22 AM
Sydwayz's Avatar
Forum Regulator
Check the solenoids on the pump. You will lose a solenoid long before you lose a pump. They are about $25 bucks, and there is one for up, and one for down.
There is a trim pump (used) for sale on the Richmond, VA Craigslist in the Boats section.
Sydwayz is offline
Old 08-03-2012 | 11:19 AM
I've got one and will be going through your area tomorrow morn
Unlimited jd is offline
Old 08-10-2012 | 09:51 AM
thanks guyz, i got a take out complete pump kit from stanleys marina for cheep$$$ the system was full of water, one cylinder cap was loose must have been that way for a while thanks agin tho
